Normal Topic Container as an obstacle issue (Read 2222 times)
Jan Lyson
Dec 4th, 2019 at 3:14pm
I have a problem with setting a container as an obstacle. When I do it nothing seems to be different, links are still routed through it (see attached image). Am I missing something?
Re: Container as an obstacle issue
Reply #1 - Dec 5th, 2019 at 7:04am
The default QuickRouter never treats containers as obstacles at this time. You could set Diagram.LinkRouter to a GridRouter instance; that one has some dedicated handling for containers, setting them as obstacles for external links while still allowing routing of internal links. If your containers won't contain any links, or internal links won't need to be routed, you could probably add some locked background nodes to them to serve as the obstacle for QuickRouter too.
Jan Lyson
Reply #2 - Dec 5th, 2019 at 8:18am
thank you, I tried it and it really treats containers as obstacles, but it also causes that links are not routed orthogonally sometimes. GridRouter doesn't have any property for this.
Reply #3 - Dec 5th, 2019 at 8:26am
For orthogonality try setting links' Shape to Cascading, or RoutingOptions.SmartPolylineEnds to false.
Jan Lyson
Reply #4 - Dec 5th, 2019 at 2:26pm
thanks a lot, setting link's Shape property to Cascading helped.
