Normal Topic Blinking on resizing (Read 1081 times)
Anna Malashkina
Dec 6th, 2019 at 11:46am
We use the following code to redraw on resize:
const rect = diagram.getContentBounds().clone();
diagram.zoomToRect(rect);
diagram.invalidate();
But it leads to diagram blinking during resizing. Is it possible to avoid blinking?
Re: Blinking on resizing
Reply #1 - Dec 9th, 2019 at 10:54am
Hi Anna,
Check if it's any better if you replace invalidate() call with repaint(), the latter doing an immediate repaint of the canvas. Also assuming you have diagram.setVirtualScroll(true) set, otherwise there are are lot of DOM operations like resizing and scrolling that might interfere before the repaint.
