Normal Topic Can we handle click Up and click down in custom node? (Read 2037 times)
Shafi
Jan 17th, 2018 at 9:14am
Hi
Can we handle two different events click up/down event for custom node? As I can find any event in library.
If your answer is no then please let me know how can we handle click and double event for same diagram for click event we are using below code.
Code (Javascript)
        this.diagram.addEventListener(Events.nodeClicked, (sender, args) => {
            const destinationVO = args.link.destination.data;
            const originVO = args.link.origin.data;
            this.linkDeleting.emit({ destination: destinationVO, origin: originVO });
        this.diagram.addEventListener(Events.nodeDoubleClicked, (sender, args) => {
            console.log('node clicked twice');
In above code click is working but double click event never get fired can you please let me know where is the problem with my code.
Note : I am creating custom node using updateVisuals.
Ankur Shah
Lyubo
MindFusion team
Re: Can we handle click Up and click down in custom node?
Reply #1 - Jan 17th, 2018 at 12:10pm
You can handle the diagram canvas mouse events and check for an item under the cursor. For reference, check this topic: https://mindfusion.eu/Forum/YaBB.pl?num=1473921360/1#1.
As for nodeClicked and nodeDoubleClicked, they're raised as expected in my tests. Maybe there's something in your code, not shown here, that prevents the click event from firing.
Lyubo
