Normal Topic How to fix scrollbar bug? (Read 1797 times)
Brarord
Jan 2nd, 2020 at 6:58am
Hi!
I have little problem with scrollbar. It's not that easy to explain, so I'll need some screenshots.
1. This is my tableNode:
2. When I grab the slider here:
3. and then move the mouse down even a millimeter:
4. then the whole slider will move down in a second, until my cursor is at the very top of the slider. Only from this moment I will be able to use the slider smoothly.
I hope you understand what I mean. Anyway, I'm not sure if it can be fixed without interfering with the library. Maybe Mr. Slavcho will know something? Or someone else from support? I would be very grateful, because if it is possible to fix it, I would prefer to fix it, because of my pedantism Cheesy
Thank you for all your help so far. The fate of my engineering work depends on this. Cry
Regards
poor student Undecided
Online
Re: How to fix scrollbar bug?
Reply #1 - Jan 2nd, 2020 at 2:08pm
Our developer will try to fix this fateful issue for upcoming release Wink
Brarord
Reply #2 - Jan 3rd, 2020 at 3:34am
That's great, thanks for the information. :]
Online
Reply #3 - Feb 10th, 2020 at 1:30pm
This version should fix it -
https://mindfusion.eu/_beta/jsdiag34.zip
