Normal Topic How to avoid node overlap with TableNode (Read 1696 times)
Shafi
Jan 7th, 2020 at 2:09pm
How to avoid overlapping of nodes in case of TableNodes? When the user adds many columns in the node, the overlapping with existing nodes is undesirable.
Re: How to avoid node overlap with TableNode
Reply #1 - Jan 9th, 2020 at 5:50am
Are you using any automatic layout, or need to redistribute nodes placed by end users?
Shafi
Reply #2 - Jan 10th, 2020 at 10:01am
I do not use any default layout. I also want to arrange nodes/cells added by end users.
Reply #3 - Jan 13th, 2020 at 5:33am
You can find if the modified table overlaps any others using this method -
function findOverlaps(modifiedNode, minDist)
	var bounds = modifiedNode.getBounds();
	bounds.inflate(minDist - 1, minDist - 1);
	var overlaps = [];
	for (var i = 0; i < diagram.nodes.length; i++)
		var node = diagram.nodes[i];
		if (modifiedNode == node)
			continue;
		if (bounds.intersectsWith(node.getBounds()))
			overlaps.push(node);
	return overlaps;
and the move the intersecting nodes to the right. That might introduce new overlaps so you'll have to keep processing until all removed -
function removeOverlaps(modifiedNode, minDist)
	var queue = [];
	queue.push(modifiedNode);
	while (queue.length > 0)
		var node = queue.shift();
		var nodeCenter = node.getCenter();
		var overlaps = findOverlaps(node, minDist);
		for (var i = 0; i < overlaps.length; i++)
			var overlap = overlaps[i];
			var ovrCenter = overlap.getCenter();
			var ovrBounds = overlap.getBounds().clone();
			var dx = ovrCenter.x - nodeCenter.x;
			var dy = ovrCenter.y - nodeCenter.y;
			//if (Math.abs(dx) > Math.abs(dy))
				// offset horizontally
				ovrBounds.x = node.bounds.right() + minDist;
			//else
				// offset vertically
				//ovrBounds.y = node.bounds.bottom() + minDist;
			// shifting the node might introduce new overlaps, continue processing
			overlap.setBounds(ovrBounds, true);
			queue.push(overlap);
E.g. call this after adding columns to a table, or from a nodeModified event handler in case users dragging a node onto another.
