Normal Topic Dashboard with custom blocks (Read 1997 times)
liza
Jan 14th, 2020 at 11:02am
Hi, I want to create a dashboard in which there will a tool box which contains different sizes blocks, A user can create a dashboard by simply drag and drop the blocks and it will fit to the page size.blocks types: small, medium,rectangle etc. Please give some idea if it is possible with this.
AIM
Re: Dashboard with custom blocks
Reply #1 - Jan 14th, 2020 at 11:37am
You can add your prototype nodes of different sizes to NodeListView, and drag and drop to the diagram canvas will clone the nodes. Set NodeListView.iconSize to null and it will draw with your sizes instead of applying a uniform one.
liza
Reply #2 - Jan 15th, 2020 at 5:17am
Can you please help me with some example, I didn't get how to set the different sizes.
AIM
Iva_P
Reply #3 - Jan 15th, 2020 at 11:12am
You can get the desired result by adding the following lines to the "Controls" sample of the control:
Code (Javascript)
//where the NodeListView gets initialized
nodeList.setIconSize(null);
nodeList.setDefaultNodeSize (null);
Code (Javascript)
function initNodeList(nodeList, diagram)
    //inside the cycle where shape prototypes are created
    node.setBounds(new MindFusion.Drawing.Rect(0, 0, (i+1)*10, (i+1)*10));
Let me know if you want me to send you the modified sample.
