Hot Topic (More than 10 Replies) How to adjust ContainerNode's Size? (Read 4822 times)
Gu Wenwei
Feb 9th, 2020 at 3:45am
How to adjust the Distance (a,b,c,d)?
How to adjust Size(e) with mouse
Re: How to adjust ContainerNode's Size?
Reply #1 - Feb 10th, 2020 at 6:42am
Set container's Margin property.
Set these properties to values different than the default ones, e.g. try All and SquareHandles instead -
ContainerNode()
	EnabledHandles = AdjustmentHandles.Move;
	HandlesStyle = HandlesStyle.MoveOnly;
Gu Wenwei
Reply #2 - Feb 10th, 2020 at 7:52am
thx
EnabledHandles = AdjustmentHandles.All;
HandlesStyle = HandlesStyle.Invisible;
another question:
How to know ContainerNode [000] contains Node[001~004]
or
How to know Node[001~004] 's parent is ContainerNode [000]
Reply #3 - Feb 10th, 2020 at 8:07am
Containers are implemented via Group objects, and you can get child nodes / parent container through the SubordinateGroup.AttachedNodes / MasterGroup.MainItem properties. We've started migrating this to dedicated APIs for containers in a few of our platforms (e.g. node.Container), which will be available in WinForms version too later this year, but for time being you'll need to use the groups API. There's also a static ContainerNode.GetContainer(childNode) helper method.
Gu Wenwei
Reply #4 - Feb 11th, 2020 at 12:55pm
How to know Node[001~004] is in ContainerNode [000]
Reply #5 - Feb 11th, 2020 at 2:14pm
try container.SubordinateGroup.AttachedNodes.
Gu Wenwei
Reply #6 - Feb 13th, 2020 at 10:25am
How to set ContainerNode's Rounded Radius?
Reply #7 - Feb 13th, 2020 at 11:42am
Try the diagram.RoundRectFactor property.
Gu Wenwei
Reply #8 - Feb 14th, 2020 at 2:49am
How to automatically move Node/ ContainerNode to align to the grid
Reply #9 - Feb 14th, 2020 at 6:40am
You can find nearby grid point by calling diagram.AlignPointToGrid(node.Bounds.Location), and then call node.Move() to move the node to that point.
Gu Wenwei
Reply #10 - Feb 14th, 2020 at 8:34am
thx very much.
Gu Wenwei
Reply #11 - Feb 15th, 2020 at 4:58am
Why move the ContainerNode's Nodes back to their original places
Reply #12 - Feb 17th, 2020 at 6:12am
Sorry, I can't understand the question.
