Normal Topic Error on WinForms Designer view when attempting to use custom layout (Read 2089 times)
Dan the Coder
.NET and JS Dev
Feb 12th, 2020 at 3:03pm
I am looking to extend some additional functionality to the Winforms virtual keyboard, so I am creating a custom UserControl which contains the VirtualKeyboard. In this UserControl I am setting a LayoutsFolder and custom layout with the code below:
public CulturedKeyboard()
            InitializeComponent();
            virtualKeyboard.LayoutsFolder = "\\Keyboard\\Layouts";
            virtualKeyboard.TemplateLayout = KeyboardLayout.Create("englishLayout.xml");
When I place this new UserControl onto a Form for use, the Designer View shows an error message "Could not find a part of the path 'C:\Keyboard\Layouts\englishLayout.xml'. "  How can I call this layout correctly? It is not showing the VirtualKeyboard control with the custom layout in the UserControl or on the Form and even when loading the application I receive an error. Thanks!
Online
Re: Error on WinForms Designer view when attempting to use custom layout
Reply #1 - Feb 12th, 2020 at 3:43pm
Files from LayoutsFolder are loaded automatically when Mode is set to Custom and file name from the folder matches current language id (based on the number in file name added by keyboard creator). Other than that, the LayoutsFolder path is not prepended automatically to names you pass to KeyboardLayout.Create method, so the error message you cite should happen only if that's also your process' current directory I guess. If you will be loading only that specific englishLayout file, forget about LayoutsFolder and just call KeyboardLayout.Create passing full path to the file.
