Normal Topic diagram component for React, beta version (Read 1830 times)
Feb 19th, 2020 at 2:23pm
We are beta testing a React DiagramView component. It renders a MindFusion.Diagramming.Diagram instance assigned to "diagram" prop as its model. At this time the following properties can be set from JSX too: allowInplaceEdit, autoResize, backBrush, behavior, defaultShape, enabled, linkHeadShapeSize, linkShape, roundedLinks, routeLinks, showAnchors, showGrid. All diagram events can be handled through JSX syntax as well:
this.state.diagram = new mf.Diagramming.Diagram();
<DiagramView
    diagram={this.state.diagram}
    {...props}
    onNodeClicked={(diagram, args) => this.onDiagramNodeClicked(diagram, args)}
    onLinkCreating={(diagram, args) => this.onDiagramLinkCreating(diagram, args)}
    onDiagramChanged={diagram => this.onDiagramChanged(diagram)} />
If anyone is interested in trying this out, please install the library from npm:
npm i diagram-library-react@1.0.0-beta.2
Several examples are available here:
https://mindfusion.eu/_beta/react-diagram-samples.zip
Re: diagram component for React, beta version
Reply #1 - Apr 23rd, 2020 at 5:14am
The helper diagram UI controls are now available as React components too:
Overview
The Overview component provides following props: id, diagram, enabled, backColor, dimColor, scaleFactor, scaleMode, allowZoom, autoScrollAmount
NodeListView
NodeListView provides following props: id, enabled, iconSize, defaultNodeSize, padding, orientation, tooltipDelay, shapeLibraryLocation, nodes, captions. It raises nodeSelected event when a node is selected in the view. The addNode(node, caption) method can be used to add nodes from code-behind, while nodes and captions props can be set to arrays of nodes and their captions.
ZoomControl
ZoomContro provides following props: id, diagram, enabled, cornerRadius, padding, snapToZoomStep, tickPosition, showLabel, textColor, shadowColor, innerColor, borderColor, activeColor, fill, backColor, scrollStep, zoomStep, maxZoomFactor, minZoomFactor, zoomFactor.
Ruler
Ruler provides following props: id, unit, enableGuides, projectRotatedBounds, negatedY, negatedX, verticalScaleVisible, horizontalScaleVisible, pointerColor, textColor, guideColor, projectionColor, backColor, foreColor. The Ruler should be set as the parent component of DiagramView:
<Ruler>
    <DiagramView diagram={this.state.diagram} ... />
</Ruler>
The new components are available in diagram-library-react@1.0.0 version on npm. Updated sample project here shows them on last tab page:
