Normal Topic Shapes Decision Find True-False Link (Read 3675 times)
Katmer
Mar 6th, 2020 at 5:58am
How can i find true and false link in decision shape node?
Re: Shapes Decision Find True-False Link
Reply #1 - Mar 6th, 2020 at 6:08am
The control does not assign intrinsic boolean values to links, you could do that yourself by setting the Tag or Id property to true / false when creating a new DiagramLink.
Alternatively if you use a position-based convention for links being true or false (like starting left or right from the node), you could check the links' OriginIndex property signifying the anchor point the link connects to (also assuming you set decision nodes' AnchorPattern).
Katmer
Reply #2 - Mar 6th, 2020 at 6:17am
I set anchorpattern like below.
AnchorPattern = new AnchorPattern(
                            new AnchorPoint[]
                                new AnchorPoint(50, 0, true, false, MarkStyle.Custom),
                                new AnchorPoint(50, 100, false, true, MarkStyle.Custom),
                                new AnchorPoint(100, 50, false, true, MarkStyle.Custom),
                            AnchorPattern.Points[0].Tag = 0;
                            AnchorPattern.Points[1].Tag = 1;
                            AnchorPattern.Points[2].Tag = 2;
But OriginIndex -1 for all outgoinglinks.
Katmer
Reply #3 - Mar 6th, 2020 at 6:35am
I found the problem. Anchorpattern is working. But when I arrange layout like that:
var layout = new MindFusion.Diagramming.Layout.DecisionLayout();
            layout.HorizontalPadding = 10;
            layout.VerticalPadding = 10;
            layout.StartNode = diagram1.FindNode("start");
            layout.Arrange(diagram1);
originindex or originanchor values change -1.
Katmer
Reply #4 - Mar 6th, 2020 at 7:04am
So do you have any suggestion?
Reply #5 - Mar 6th, 2020 at 7:10am
Indeed DecisionLayout moves links around the node and detaches them from anchor points. We don't have any layout class that would keep true/false links on a fixed side of a node, a position-based convention would help you only for flowcharts drawn by the user I guess.
Reply #6 - Mar 6th, 2020 at 7:25am
Suggestion for determining link true/false type by automatic position alone? It might be possible if your diagrams are strictly binary trees and you apply TreeLayout - then the order of links would depend on the order of child nodes though, so still something you must set at diagram creation time yourself.
