Normal Topic Why does the diagramView display X (Read 2145 times)
Gu Wenwei
Mar 9th, 2020 at 12:08pm
Re: Why does the diagramView display X
Reply #1 - Mar 9th, 2020 at 1:32pm
Windows Forms shows that if drawing code throws an exception. Try using Visual Studio's 'stop when exception thrown' option to see exact stack trace.
Gu Wenwei
Reply #2 - Mar 10th, 2020 at 9:29am
Where is the drawing code?
such as demo file "FlowCharter"
Reply #3 - Mar 10th, 2020 at 9:37am
It might be control's standard drawing code, or might be custom-drawing code in DrawNode event handlers /  Draw overrides in derived node classes. From the Ctrl+Alt+E dialog, set the checkbox for 'when thrown' option for CLR exceptions and it should show the exact problem.
GDI+ itself throws out-of-memory exceptions sometimes when drawing arcs with a dashed line - if you find that's the problem, enable the DiagramView.CatchGdiPlusExceptions property and the control with catch and ignore the exceptions.
