Normal Topic The Diagram nested custom user controls (Read 1902 times)
D
Mar 16th, 2020 at 1:40am
Hello, I want to put another control on the diagram in the ruler, but the realization function of the ruler is not available, such as: the ruler moves with the current mouse position, etc., how to solve this problem?
Re: The Diagram nested custom user controls
Reply #1 - Mar 16th, 2020 at 6:31am
If you mean your custom control is on top of the ruler and blocks mouse messages, try setting the UIElement.IsHitTestVisible property to false.
D
Reply #2 - Mar 16th, 2020 at 7:25am
I want to replace the diagram in the ruler with my custom control, and all functions of the ruler are still possible
Reply #3 - Mar 16th, 2020 at 8:14am
That's not supported at this time, the Ruler is designed to host a Diagram instance as a direct child. Maybe try creating a custom control that contains a Ruler child, or try inheriting custom control from Diagram / changing Diagram's template.
Reply #4 - Mar 16th, 2020 at 8:16am
it could also be possible to add your custom control to Ruler's template...
D
Reply #5 - Mar 17th, 2020 at 12:46pm
Thanks Smiley
