Very Hot Topic (More than 25 Replies) Change the measurement unit in Diagram (Read 6650 times)
D
Re: Change the measurement unit in Diagram
Reply #15 - Mar 30th, 2020 at 3:18pm
private void ImageManipulation (string path)
diagram.MeasureUnit = GraphicsUnit.Millimeter;
ruler.Unit = RulerUnit.Millimeter;
var myImage = new BitmapImage (new Uri (path));
var imageWidthPx = myImage.PixelWidth * 96 / myImage.DpiX;
var imageHeightPx = myImage.PixelHeight * 96 / myImage.DpiY;
var imageWidth = GraphicsUnit.Pixel.Convert (imageWidthPx, diagram.MeasureUnit);
var imageHeight = GraphicsUnit.Pixel.Convert (imageHeightPx, diagram.MeasureUnit);
imageNode = diagram.Factory.CreateShapeNode (0, 0, imageWidth, imageHeight);
imageNode.Image = myImage;
imageNode.Shape = Shapes.Rectangle;
imageNode.CustomDraw = CustomDraw.Additional;
imageNode.ImageAlign = ImageAlign.Fit;
var overlayNodeWidth = 50;
var overlayNodeHeight = 50;
overlayNode = diagram.Factory.CreateShapeNode (imageNode.Bounds.Right-overlayNodeWidth,
imageNode.Bounds.Bottom-overlayNodeHeight, overlayNodeWidth, overlayNodeHeight);
overlayNode.Shape = Shapes.Rectangle;
overlayNode.Brush = Brushes.Transparent;
overlayNode.Locked = true;
overlayNode.AttachTo (imageNode, AttachToNode.BottomRight);
I have set
diagram.MeasureUnit = GraphicsUnit.Millimeter as you said earlier;
How can graphics.MeasureUnit be set to Millimeter, please give me sample code.
Lyubo
MindFusion team
Reply #16 - Mar 30th, 2020 at 3:35pm
What is the value of diagram.MeasureUnit at the time you're doing the conversion?
D
Reply #17 - Mar 30th, 2020 at 3:50pm
Hey, Lyubo. Smiley
D
Reply #18 - Mar 30th, 2020 at 4:01pm
This place is wrong:
         private void diagram_DrawNode(object sender, DrawNodeEventArgs e)
            if (e.Node != imageNode)
                return;
            var graphics = e.Graphics;
            var clip = new CombinedGeometry(
                GeometryCombineMode.Exclude,
                new RectangleGeometry(imageNode.Bounds),
                new RectangleGeometry(overlayNode.Bounds));
            var translate = new TranslateTransform(-imageNode.Bounds.X, -imageNode.Bounds.Y);
            graphics.PushTransform(translate);
            graphics.PushClip(clip);
            graphics.DrawRectangle(new SolidColorBrush(Color.FromArgb(120, 0, 0, 0)), null, imageNode.Bounds);
            graphics.Pop();
            graphics.Pop();
D
Reply #19 - Mar 31st, 2020 at 1:41am
Hey,Lyubo. Smiley
My current program is modified to have only this code to look for errors.
But still couldn't figure out the problem, the only possibility of error lies in this expression: var imageWidth = GraphicsUnit.Pixel.Convert (imageWidthPx, diagram.MeasureUnit);
MainWindow.xmal:
<Window
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:local="clr-namespace:MeasurementUnit"
xmlns:diag="http://mindfusion.eu/diagramming/wpf" x:Class="MeasurementUnit.MainWindow"
mc:Ignorable="d"
Title="MainWindow" Height="450" Width="800" Loaded="Window_Loaded">
<Grid>
<diag:Ruler Name="ruler" ShowIcon="False" FontSize="11" Grid.Row="1" Grid.Column="1" BorderBrush="Black">
<diag:Diagram x:Name="diagram"
AllowDrop="True"
VerticalAlignment="Top"
HorizontalAlignment="Left"
DefaultShape="RoundRect"
Behavior="Pan"
GridSizeX="15" GridSizeY="15" RestrictItemsToBounds="InsideOnly" RightButtonActions="None"
Bounds="-500,-500,2000,2000"
</diag:Diagram>
</diag:Ruler>
</Grid>
</Window>
MainWindow.xmal.cs:
using Microsoft.Win32;
using MindFusion.Diagramming.Wpf;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
namespace MeasurementUnit
/// <summary>
/// MainWindow.xaml
/// </summary>
public partial class MainWindow : Window
public MainWindow()
InitializeComponent();
private void Window_Loaded(object sender, RoutedEventArgs e)
OpenFileDialog openfiledialog = new OpenFileDialog
Filter = "*.jpg;*.png;*.jpeg;*.bmp;*.gif|*.*"
if ((bool)openfiledialog.ShowDialog())
ImageManipulation(openfiledialog.FileName);
static ShapeNode imageNode;
private void ImageManipulation(string path)
var myImage = new BitmapImage(new Uri(path, UriKind.Relative));
var imageWidth = GraphicsUnit.Pixel.Convert(imageWidthPx, diagram.MeasureUnit);
var imageHeight = GraphicsUnit.Pixel.Convert(imageHeightPx, diagram.MeasureUnit);
imageNode = diagram.Factory.CreateShapeNode(0, 0, imageWidth, imageHeight);
Figure 1 is the picture I tested, you can check.
D
Reply #20 - Mar 31st, 2020 at 1:45am
Supplement: Figure 2 is the result after program operation.
Lyubo
MindFusion team
Reply #21 - Mar 31st, 2020 at 5:21am
Add the following method:
private double GetScreenDpi()
    double dpi = 96;
    PresentationSource source = PresentationSource.FromVisual(this);
    if (source != null)
        dpi =  96.0 * source.CompositionTarget.TransformToDevice.M11;
    return dpi;
and modify your current code with this:
var imageWidthPx = myImage.PixelWidth * GetScreenDpi() / myImage.DpiX;
var imageHeightPx = myImage.PixelHeight * GetScreenDpi() / myImage.DpiY;
It should display properly after these changes.
Lyubo
MindFusion
D
Reply #22 - Mar 31st, 2020 at 5:37am
Yes, it worked. Thank you, Lyubo. Smiley
Can you explain to me what this method does: GetScreenDpi ()
Lyubo
MindFusion team
Reply #23 - Mar 31st, 2020 at 5:59am
It returns the device-dependent screen DPI setting.
D
Reply #24 - Mar 31st, 2020 at 6:04am
Great, you taught me another point of knowledge Wink
D
Reply #25 - Mar 31st, 2020 at 6:06am
Lyubo, I currently have several questions posted on the new topic, waiting for you to teach me Smiley
