Normal Topic Double-click on the diagram to interoperate with ruler (Read 1467 times)
D
Mar 31st, 2020 at 5:48am
Hey, Lyubo. Smiley
        private void diagram_NodeDoubleClicked(object sender, NodeEventArgs e)
            var node = e.Node;
            if (node.MasterGroup != null)
                node = node.MasterGroup.MainItem as DiagramNode;
            var posX = e.MousePosition.X - node.GetCenter().X;
            var posY = e.MousePosition.Y - node.GetCenter().Y;
            var newPos = new Point(
                diagram.Viewport.X + diagram.Viewport.Width / 2 - node.Bounds.Width / 2 - posX,
                diagram.Viewport.Y + diagram.Viewport.Height / 2 - node.Bounds.Height / 2 - posY);
            node.SetBounds(new Rect(newPos, node.Bounds.Size), true, true);
This method currently implements that when you double-click on any point in node.MasterGroup.MainItem, the point moves to the center of the view, but the ruler does not follow. I want the ruler to follow. What changes should be made in this method?
Lyubo
MindFusion team
Re: Double-click on the diagram to interoperate with ruler
Reply #1 - Mar 31st, 2020 at 6:43am
In order for the node to remain fixed to the 0,0 position, instead of moving it, you need to scroll the view instead:
            diagram.NodeDoubleClicked += (sender, args) =>
                var node = args.Node;
                var posX = args.MousePosition.X - (diagram.Viewport.X + diagram.Viewport.Width / 2);
                var posY = args.MousePosition.Y - (diagram.Viewport.Y + diagram.Viewport.Height / 2);
                diagram.ScrollX += posX;
                diagram.ScrollY += posY;
Lyubo
MindFusion
D
Reply #2 - Mar 31st, 2020 at 6:54am
I fully understand, thank you very much for your guidance, Lyubo Wink
