Hot Topic (More than 10 Replies) TextBox controls the length and width of the overlayNode through the mouse wheel (Read 5240 times)
D
Mar 31st, 2020 at 7:25am
Hey, Lyubo. Smiley
The two TextBoxes are bound to the length and width of the overlayNode, so that the length and width of the overlayNode are displayed in the TextBox in real-time. When the cursor is displayed in the TextBox, it responds to the mouse wheel event, and the value of the TextBox is increased or decreased by the wheel to change the length and width of the overlayNode.
D
Re: TextBox controls the length and width of the overlayNode through the mouse wheel
Reply #1 - Mar 31st, 2020 at 10:29am
private void RibbonButton_Click(object sender, RoutedEventArgs e)
if (overlayNode == null)
return;
double x = overlayNode.Bounds.X,
y = overlayNode.Bounds.Y;
// Get the new values from the 2 text boxes
double newValue;
if (double.TryParse(textBoxW.Text, out newValue))
x = newValue;
if (double.TryParse(textBoxH.Text, out newValue))
y = newValue;
var newBounds = new Rect(imageNode.Bounds.Right - x, imageNode.Bounds.Bottom - y, x, y);
// Change the node's position / dimensions
overlayNode.SetBounds(newBounds, true, true);
imageNode.InvalidateVisual();
I use this method RibbonButton_Click (object sender, RoutedEventArgs e) to achieve the value of the two TextBox changes the length and width of the overlayNode. But now I want to extend the two TextBoxes to control the length and width of the overlayNode. The implementation functions are as follows: one: displaying the length and width values ​​of the overlayNode in two TextBoxes in real time; two: when the cursor is displayed in the TextBox, the TextBox responds to the mouse wheel event and changes the length and width values ​​of the overlayNode by scrolling with the wheel. How can I achieve this?
D
Reply #2 - Mar 31st, 2020 at 1:03pm
Hi Lyubo, I have been waiting for your answer Smiley
Lyubo
MindFusion team
Reply #3 - Apr 1st, 2020 at 5:18am
Subsribe to the TextBox.MouseWheen event and use that handler for the width TextBox:
		private void textBoxW_MouseWheel(object sender, MouseWheelEventArgs e)
				return;
                        // this value is used only for demonstration, adjust as per your requirements
			var delta = e.Delta > 0 ? 10 : -10;
			var newBounds = new Rect(overlayNode.Bounds.X - delta, overlayNode.Bounds.Y, overlayNode.Bounds.Width + delta, overlayNode.Bounds.Height);
			textBoxW.Text = overlayNode.Bounds.Width.ToString();
Attach another handler to the height TextBox with similar logic to change the node's height.
Lyubo
MindFusion
D
Reply #4 - Apr 1st, 2020 at 6:33am
Thanks a lot, Lyubo Smiley
                return;
I currently use the mouse to scroll the textBoxW, but it doesn't respond to this method: textBoxW_MouseWheel (object sender, MouseWheelEventArgs e). It just responds to the menu page up or page down. What changes do I need to make?
D
Reply #5 - Apr 1st, 2020 at 8:45am
Hey, Lyubo. Smiley
Because these two TextBoxes are nested inside the Ribbon menu control, the MouseWheel event currently only responds to the Ribbon. How can I implement a response to the MouseWheel event of the TextBox without affecting the MouseWheel event of the Ribbon. How can I achieve this? Is there any sample code?
D
Reply #6 - Apr 1st, 2020 at 10:40am
Hello, Lyubo, Smiley I urgently need your help, please guide me to complete this work.
Lyubo
MindFusion team
Reply #7 - Apr 2nd, 2020 at 4:52am
Handle PreviewMouseWheel instead of the MouseWheel evnt and set e.Handled to true.
Lyubo
MindFusion
D
Reply #8 - Apr 2nd, 2020 at 6:14am
I tried to use this method PreviewMouseWheel, and set e.Handled = true; but there is no response method PreviewMouseWheel, I do not know where to set it in place, what is missing? Please tell me how to modify it?
xaml:
<StackPanel>
                                <DockPanel>
                                    <Label Content="PCB长度"/>
                                    <RibbonTextBox Name="textBoxW" PreviewTextInput="tb_PreviewTextInput" InputMethod.IsInputMethodEnabled="False" PreviewMouseWheel="numberWheelchange" />
                                </DockPanel>
                                <DockPanel>
                                    <Label Content="PCB宽度"/>
                                    <RibbonTextBox Name="textBoxH" PreviewTextInput="tb_PreviewTextInput" InputMethod.IsInputMethodEnabled="False" PreviewMouseWheel="numberWheelchange" />
                                </DockPanel>
                                <DockPanel>
                                    <Label Content="轨道宽度"/>
                                    <RibbonTextBox/>
                                </DockPanel>
                            </StackPanel>
cs:
private void numberWheelchange(object sender, MouseWheelEventArgs e)
            if (textBoxW.IsSelectionActive)
                if (textBoxW.Text != null)
                        return;
            if (textBoxH.IsSelectionActive)
                if (textBoxH.Text != null)
                        return;
                    var newBounds = new Rect(overlayNode.Bounds.X, overlayNode.Bounds.Y - delta, overlayNode.Bounds.Width, overlayNode.Bounds.Height + delta);
            e.Handled = true;
Lyubo
MindFusion team
Reply #9 - Apr 2nd, 2020 at 7:45am
The code you posted above works in my test. There must be something else preventing you from achieving the behavior you want.
Rgards,
Lyubo
MindFusion
D
Reply #10 - Apr 2nd, 2020 at 7:49am
Thank you very much, Lyubo. Smiley It must be the MouseWheel of the Ribbon control that overwrites the MouseWheel I set.
