Normal Topic Container properties and event (Read 2912 times)
Jan Lyson
Apr 2nd, 2020 at 10:16am
I have three questions.
1. I cannot find and event that will inform me about container size change. For example, when I have two nodes within the container and I move one node closer to the second one, the container shrinks. I need to react to this change. Does exist an event for this situation?
2. Is it possible to add container property AutoGrow to WPF? I would like to resize some containers manually. I found out that this property is available only in WinForms.
3. Somewhere I read that it is not possible to change ContainerNode background. Is it even in your roadmap? Or is there any workaround for it?
Thanks for the answers
Jan
Re: Container properties and event
Reply #1 - Apr 3rd, 2020 at 7:25am
1. There's no dedicated event for this. Some ways you could detect it:
- check container's Bounds from NodeModified event raised for child. you might need to do that recursively if allowing nested containers.
- create a binding expression for container's Bounds property (https://docs.microsoft.com/en-us/dotnet/framework/wpf/data/how-to-create-a-bindi...)
- if using custom container class by chance, override OnSizeChanged
- if using undo/redo, handle ActionRecorded and examine ModifyCommand instances
2. We'll have it in mind for next release.
3. You should be able to change container's background via Brush property. Try setting it to ImageBrush or DrawingBrush if you need more complex backgrounds.
Jan Lyson
Reply #2 - Apr 3rd, 2020 at 4:18pm
thank you, I did what I wanted  Smiley
Jan
donep
Love MindFusion
Reply #3 - May 8th, 2020 at 12:09am
Yes, I want too. Please give us AutoGrow property to WPF Container Cheesy
Reply #4 - May 8th, 2020 at 6:32am
Roll Eyes coming soon
Reply #5 - May 9th, 2020 at 7:43am
This build adds ContainerNode.AutoGrow property -
https://mindfusion.eu/_beta/wpfdiag_autogrow.zip
