Normal Topic NodeCreating event not firing (Read 1749 times)
PeteWhite
Apr 7th, 2020 at 3:03pm
Hi All,
I am currently evaluation the Diagramming for WinForms component (v6.6) and I must say I am very impressed.
One thing though, I am using the NodeListView to allow the user to drag ShapeNodes onto the DiagramView, however, the NodeCreating event doesn't seem to be firing.
I want to be able to restrict the user to only one instance of certain nodes.
Any assistance would be appreciated.
Cheers,
Pete
Re: NodeCreating event not firing
Reply #1 - Apr 8th, 2020 at 6:13am
That raises drag-and-drop events, you can check node type from DragOver handler like this -
void diagramView_DragOver(object sender, DragEventArgs e)
	e.Effect = DragDropEffects.Copy;
	var draggedNode = e.Data.GetData(typeof(DraggedNode)) as DraggedNode;
	if (draggedNode != null && draggedNode.Node is TableNode)
		e.Effect = DragDropEffects.None;
PeteWhite
Reply #2 - Apr 9th, 2020 at 10:27am
Thanks, that gave me a good starting point to sort it out.
