Normal Topic Diagram Pan and scroll using only Mouse Middle button! (Read 2744 times)
MikeHeal
Apr 8th, 2020 at 10:42pm
Is there a way by which we can pan and scroll together using the mouse middle button (only) !?
Used the code:
diag.Behavior = Behavior.Pan;
but it just changes the mode to Pan, we still have to additionally use Left mouse button to Scroll. Can we combine them to just Middle mouse button !  Huh
Thanks.
Re: Diagram Pan and scroll using only Mouse Middle button!
Reply #1 - Apr 9th, 2020 at 5:30am
You can pan with middle button by setting diagram.MiddleButtonActions = MouseButtonActions.Pan; I'm not sure what's the difference between pan and scroll inferred in your post. If you mean ScrollVewer should scroll using middle button, see e.g. https://stackoverflow.com/questions/5426232/how-can-i-make-wpf-scrollviewer-midd...
MikeHeal
Reply #2 - Apr 9th, 2020 at 6:26pm
Hello Slavcho,
Thanks for the reply.
diagram.MiddleButtonActions = MouseButtonActions.Pan; puts the diagram in Pan mode. Now, in order to pan/scroll (move/drag) the diagram we Have to use Left mouse key, which i wanted to avoid.
I tried the StackOverflow's solution, that doesn't give a smooth experience.
Reply #3 - Apr 10th, 2020 at 4:44am
MiddleButtonActions = Pan should let you pan with middle button without changing Behavior to Pan - the left button will keep doing whatever it does in other Behavior modes you keep it set to - e.g. select items in SelectOnly.
MikeHeal
Reply #4 - Apr 10th, 2020 at 4:58pm
Ok. May be i am doing something wrong on my side.
I tried:
diagram.MouseDown += OnMouseDown;
diagram.MouseUp += OnMouseUp;
private void OnMouseDown(object sender, MouseButtonEventArgs e)
if (e.MiddleButton == MouseButtonState.Pressed)
private void OnMouseUp(object sender, MouseButtonEventArgs e)
if (e.MiddleButton == MouseButtonState.Released)
diagram.MiddleButtonActions = MouseButtonActions.None;
But, this didn't help.
Reply #5 - Apr 11th, 2020 at 7:53am
MiddleButtonActions value is checked from PreviewMouseDown, so before you can toggle it in mouse events. That code doesn't make much sense anyway, why node keep the Pan value set at all times?
MikeHeal
Reply #6 - Apr 13th, 2020 at 6:06pm
Roll Eyes
Thanks for the help Slavcho.
