Normal Topic How to use LabelType.CustomText on Axis of a LineChart? (Read 2350 times)
trbld21
Apr 18th, 2020 at 8:31pm
Hi.
I'm trying to replace the LabelType.AutoScale parameter of an Axis, with my custom text. However it doesn't work. Probably I have not understood correctly something.
Thus I have the code:
Code (C++)
            Axis axis = new Axis();
            axis.MinValue = 0;
            axis.MaxValue = 288;
            axis.Interval = 1;
            axis.Tick = 1;
            axis.IntervalCount = 10;
            axis.LabelType = LabelType.CustomText;
            List<string> axisList = new List<string>();
            axisList.Add("1");
            axisList.Add("2");
            axisList.Add("3");
            axisList.Add("4");
            axisList.Add("5");
            axisList.Add("6");
            axisList.Add("7");
            axisList.Add("8");
            axisList.Add("9");
            axisList.Add("10");
            axis.Labels = axisList.AsReadOnly();
            lineChart.XAxes.Add(axis);
I would expect this code to add the numbers 1-10 in the axis, in 10 different positions equally spaced in-between them. Instead I don't get any label on the Axis of the LineChart.
What am I doing wrong?
How can I add values "1" to "10" in the Axis (while having values 0-288; thus replacing 0 with "1" and 288 with "10")?
Thanks.
Re: How to use LabelType.CustomText on Axis of a LineChart?
Reply #1 - Apr 19th, 2020 at 8:43am
The AxisSettings.CustomLabelPositionhttps://www.mindfusion.eu/onlinehelp/wpfchart/index.htm?P_MindFusion_Charting_Wp... property is meant to be used when the label type is CustomLabels to tell the control if the custom labels will be rendered at data points or at the auto scale intervals.
In your case:
axis.CustomLabelPosition = CustomLabelPosition.AutoScalePoints;
Note that the chart is initialized with one axis in the XAxes collection. So, if you don't want "axis" to be added to the default one call:
lineChart.XAxes.Clear();
before adding your new "axis".
Let me know if that works.
Kind Regards,
Iva
trbld21
Reply #2 - Apr 19th, 2020 at 9:02am
I just added your proposed code:
Code (C++)
after my code line:
Code (C++)
And it did worked! Cheesy
Thanks a lot!
