Hot Topic (More than 10 Replies) ExpandButtonClicked in Angular/typescript (Read 8865 times)
Michael Pfeifer
Re: ExpandButtonClicked in Angular/typescript
Reply #15 - May 6th, 2020 at 9:21am
Tried to do so. Now when clicking the expand button, I get a lot of errors
TypeError: Cannot read property 'emit' of undefined
    at Array.<anonymous> (diagram-library-angular.js:111)
    at MindFusion.Common.js:6
    at abt.<computed>.raiseEvent (MindFusion.Diagramming.js:6)
    at abt.<computed>.raiseExpandButtonClicked (MindFusion.Diagramming.js:6)
    at aBm.ExpandButton.onClick (MindFusion.Diagramming.js:6)
    at aKg.LinkNodesBehavior.createController (MindFusion.Diagramming.js:6)
    at Object.callBaseMethod (MindFusion.Common.js:6)
    at a1N.MouseInputDispatcher.selectController (MindFusion.Diagramming.js:6)
    at a1N.MouseInputDispatcher.onMouseMove (MindFusion.Diagramming.js:6)
When following the link, I end up in the code
        for (var v in events) {
            function addAndDelegate(event, prop) {
                prop.diagram.addEventListener(event, (sender, args) => {
                    let emitter = Reflect.get(prop, event);
                    emitter.emit({ sender, args });
            addAndDelegate(v, this);
and see that emitter is undefined.
What am I missing?
Best,
Michael
Reply #16 - May 7th, 2020 at 7:52am
diagram-library-angular@1.0.3 on npm adds expandClicked emitter to DiagramView -
(onExpandButtonClicked)="onExpandButtonClicked($event)"
Michael Pfeifer
Reply #17 - May 7th, 2020 at 9:16am
Awesome, works fine.
But one thing I noticed: The expand button does not change from + to - and vice versa though the state of node.getExpanded() is correct in the event handler. Even if I change it explicitly (again) using node.setExpanded() it does not change ...
Is there any intention to add the mousebutton which was used to click the button to the event args?
e.args.getMouseButton() always delivers 'undefined'
Reply #18 - May 7th, 2020 at 11:25am
try calling this from event handler for time being -
(node as any).expandButton.updateContent();
node.invalidate();
Michael Pfeifer
Reply #19 - May 7th, 2020 at 12:39pm
Works fine. Thanks
