Normal Topic TabbedDiagram Tab Size not changing (Read 1560 times)
IpaGuy
May 12th, 2020 at 2:45pm
I am using the TabbedDiagramView.  Whenever a diagram is edited, I would like to modify the title of the page to have an "*" added to the end of the filename displayed on the tab.  When I add this, the text on the tab gets clipped. I have tried adding extra spaces to the filename before setting the Page.Title, but this is very clunky and does not work.
Am I missing something very simple?  The only solution that I have come up with is to remove the tab, set the Title and then insert the tab back at the same index.
Online
Re: TabbedDiagram Tab Size not changing
Reply #1 - May 12th, 2020 at 6:06pm
We'll fix it for next release. For time being, you could force calculating new size by temporarily changing some layout or font related properties -
tabbedDiagramView.Document.Pages[0].Title += "***";
tabbedDiagramView.MaxTabSize++;
tabbedDiagramView.MaxTabSize--;
IpaGuy
Reply #2 - May 12th, 2020 at 11:26pm
OK, thanks for the tip!
