Normal Topic Reroute Links Programmatically (Read 2292 times)
Ktmr
May 20th, 2020 at 8:52am
I am sorting nodes when user deleted a node from diagram. But links saving their positions. How can I reroute links programmatically?
Re: Reroute Links Programmatically
Reply #1 - May 20th, 2020 at 9:18am
Try Diagram.RouteAllLinks();
Ktmr
Reply #2 - May 20th, 2020 at 9:39am
It does not work. Anything else?
Reply #3 - May 20th, 2020 at 12:00pm
I guess make sure your links are connected to nodes in the first place. Does dragging a node move any links along with it? If using node.SetBounds method to sort your nodes, verify the updateLinks argument is true.
Ktmr
Reply #4 - May 20th, 2020 at 12:15pm
It is working now after setting updateLinks true.
Thank you.
