Normal Topic establish an end date of the calendar (Read 2597 times)
annievalki
May 26th, 2020 at 10:43pm
Hello I have the one idea of creating a Calendar, when you create it you can introduce the last month/year that I want in my calendar.
My intentions was of using the SingleMonth view, but whet you reach f.e June/2020 (which was set like last month) you cannot advance to July/2020.
But I dont know if there exist a method for something like this. Any idea?
Iva_P
Re: establish an end date of the calendar
Reply #1 - May 27th, 2020 at 9:33am
You can achieve this effect by handling the visibleDateChanged event and checking of the "newDate" to be rendered is already in the date range that you do not want to show therefore the action must be stopped:
Code (Java)
calendar.addCalendarListener(new CalendarAdapter()
		@Override()
		public void visibleDateChanged(DateChangedEvent e) {
			onVisibleDateChanged(e);
//make sure that dates are rendered till the end of May
public void onVisibleDateChanged(DateChangedEvent e)
	if(e.getNewDate().getMonth() == 6)
		calendar.setDate(new DateTime(2020, 5, 31));
annievalki
Reply #2 - May 27th, 2020 at 10:43pm
Thank you very much <3 Grin Grin
