Normal Topic Trial version message shown in diagram view. (Read 3382 times)
vishalb
Jun 1st, 2020 at 10:36am
I am using "mindfusion":"version": "1.1.4",
and using diagram.setLicenseKey(key) to set the license key.
Initially it does not show the trial version message but once i load any other existing node in the same diagram area by clearing the old node using diagram.clearAll() it shows the trial version message.
Can you please suggest on the same point?
Re: Trial version message shown in diagram view.
Reply #1 - Jun 1st, 2020 at 11:25am
Either the key value you are passing to that method is incorrect, or it's for much older version. Please send me the key as private message and we'll verify.
Reply #2 - Jun 1st, 2020 at 11:29am
also note that if you have upgraded recently, you must replace your original key with latest one you receive with purchase.
vishalb
Reply #3 - Jun 2nd, 2020 at 6:03am
Sorry for the wrong version posted earlier. We are using "3.3.7"
Reply #4 - Jun 2nd, 2020 at 6:31am
The key decodes successfully in our tool but shows maintenance expired in February 2018, so latest version it will work for is v3.2. If your company has renewed maintenance & upgrades recently, you should have received a new key.
Shafi
Reply #5 - Jun 5th, 2020 at 8:20am
We are in the process of acquiring a license via Comparex. Does this license cover the actual used version 3.3.7 as well? We cannot use 3.4 right at the moment for process reasons (legal clearing not available).
Reply #6 - Jun 5th, 2020 at 8:34am
Sure, you can use any older versions you'd like.
