Normal Topic how to wrap legend items or show in multiple rows (Read 4347 times)
sami
Jun 4th, 2020 at 8:52am
hi all,
i have a wpf chart with lot of lengend items,
how can i wrap legend items or  show its in multiple rows?
help me please Embarrassed
Re: how to wrap legend items or show in multiple rows
Reply #1 - Jun 4th, 2020 at 3:40pm
Try this, possibly change x:Type to ChartLegend depending on what legend class you are using -
<Window.Resources>
    <Style TargetType="{x:Type chart:SeriesLegend}">
        <Setter Property="ItemsPanel">
            <Setter.Value>
                <ItemsPanelTemplate>
                    <WrapPanel MaxHeight="80" Orientation="Vertical" />
                </ItemsPanelTemplate>
            </Setter.Value>
        </Setter>
    </Style>
</Window.Resources>
Alternatively, you could add multiple Legend objects to the chart.
sami
Reply #2 - Jun 6th, 2020 at 9:51am
hi dear,
thanks for relpy,
my legend class is SeriesLegend,
but your code not  Work,
Reply #3 - Jun 6th, 2020 at 11:07am
That template creates a second column only if you have enough legend items to fill the 80-points MaxHeight. Change the wrap panel's Orientation to Horizontal to immediately arrange in a row instead, and set MaxWidth to specify at what points it should wrap to a second row.
sami
Reply #4 - Jun 8th, 2020 at 11:45am
hi,
ooops,very nice,
this worked,thanks a lot,
excuse me ,i have another question
my chart width properites is not fix,in the other words,the HorizontalAlignment properties of chart set to Stretch,
how to set maxwidth of wrap panel to chart real width??
is there a solution??
Reply #5 - Jun 8th, 2020 at 2:32pm
Something like this -
<WrapPanel
    MaxWidth="{Binding RelativeSource=
        {RelativeSource Mode=FindAncestor,
            AncestorType={x:Type chart:BarChart}},
        Path=Width}"
    Orientation="Horizontal" />
and you'll probably want to move legends to top or bottom of the plot, or otherwise they'll clamp the plot if on the sides -
LayoutPanel.SetDock(legend1, Dock.Bottom);
sami
Reply #6 - Jun 22nd, 2020 at 2:22pm
oh my friend,
this is very nice
,its worked
thank you Cheesy Cheesy
but,why only barchart?
you have a method for all type of chart?
Reply #7 - Jun 23rd, 2020 at 6:44am
base chart class should work too if you want this template for more chart types -
AncestorType={x:Type chart:Chart}
