Hot Topic (More than 10 Replies) EditComponent CompositeNode (Read 6752 times)
DSI
Jun 4th, 2020 at 8:12pm
Is it possible to have and Editable component in a compositeNode?
Re: EditComponent CompositeNode
Reply #1 - Jun 5th, 2020 at 8:47am
EditComponent from WinForms version won't be available in JS soon. For time being you can edit CompositeNode's Text components by double-clicking when AllowInplaceEdit is enabled. Alternatively you can initiate editing from single-click or other events by calling diagram.beginEdit(compositeNode, point).
DSI
Reply #2 - Jun 5th, 2020 at 3:42pm
Can I enable AllowInplaceEdit on individual components or only on the DiagramView (i.e. all node components)?
Reply #3 - Jun 9th, 2020 at 6:44am
It's for all items. You could try calling endEdit from enterInplaceEditMode event handler if item should not allow editing, or keep AllowInplaceEdit  disabled and call beginEdit from double/click event handlers.
DSI
Reply #4 - Jun 17th, 2020 at 8:56pm
Trying to call beginEdit from a click event but it isn't working. I think I'm trying to enable it incorrectly.
CompositeNode Template portion:
    ""component"": ""Text"",
    ""name"": ""Details"",
    ""gridRow"": 3,
    ""gridColumn"": 1,
    ""columnSpan"": 6,
    ""autoProperty"": true,
    ""text"": ""details"",
    ""font"": ""Arial 3"",
    ""clickHandler"": ""onEditClick""
Here is the corresponding JS function (I feel like this is what I'm calling incorrectly):
function onEditClick(diagram, eventArgs) {
        diagram.beginEdit(compositeNode, eventArgs.getMousePosition());
This is all in Index.cshtml of the tutorial8 mvc solution. Thank you!
Reply #5 - Jun 18th, 2020 at 6:07am
clickHandler is supported only for button components at this time. Try subscribing to nodeClicked event and calling diagram.beginEdit(args.node, args.mousePosition);
DSI
Reply #6 - Jun 19th, 2020 at 7:25pm
I currently have this in place correctly (I think):
function onLoaded(sender) {
        diagram = sender;
        diagram.addEventListener(Events.nodeClicked, onEditClick);
        var original = OrgChartNode.prototype.updateCanvasElements;
        OrgChartNode.prototype.updateCanvasElements = function () {
            original.apply(this, []);
            var back = this.getComponent('Frame');
            back.setBrush(this.getBrush());
but I keep getting the attached error in my browser console.
I have also attached my MindFusion.Diagramming.js file (Had to split this into two separate files and zip them so that they were under the 300kb attachment limit)
MindFusion_Diagramming_1.zip (Attachment deleted)
MindFusion_Diagramming_2.zip (Attachment deleted)
Reply #7 - Jun 22nd, 2020 at 7:17am
Use MindFusion.Diagramming.Events instead, or add this -
var Events = MindFusion.Diagramming.Events;
DSI
Reply #8 - Jun 22nd, 2020 at 7:18pm
I still am not able to get edit or Hyperlink (https://mindfusion.eu/Forum/YaBB.pl?num=1590780726/new) to work.  Please have a look at my index.cshtml posted below.  Thank you.
@using System.Drawing
@using MindFusion.Drawing
@using MindFusion.Diagramming
@using MindFusion.Diagramming.Mvc
@using MindFusion.Diagramming.Manipulators
@using MindFusion.Diagramming.Fluent;
@using MindFusion.Diagramming.Layout.Fluent;
@Scripts.Render("~Scripts/MindFusion.Diagramming.js");
    string template = @"{
""component"": ""SimplePanel"",
""children"":
""component"": ""Shape"",
""name"": ""Frame"",
""shape"": ""{0}"",
""pen"": ""black"",
""isOutline"": true,
""component"": ""Border"",
""padding"": ""2""
""component"": ""GridPanel"",
""columnDefinitions"": [""Auto"",""Auto"",""Auto"",""Auto"",""Auto"",""Auto"",""Auto"",""Auto"",""Auto"",""Auto""],
""rowDefinitions"": [""Auto"",""Auto"",""Auto"",""Auto""],
""children"":
""gridRow"": 0,
""gridColumn"":7,
""columnSpan"": 3,
""name"": ""Title"",
""text"": ""title"",
""font"": ""Arial bold"",
""horizontalAlignment"": ""Near""
""gridRow"": 0,
""gridColumn"":9,
""columnSpan"": 1,
""component"": ""ButtonComponent"",
""imageLocation"": ""../Content/close.png"",
""imageAlign"": ""Center"",
""cornerRadius"": 3.5,
""clickHandler"": ""onDeleteClick""
""name"": ""FullName"",
""gridRow"": 1,
""gridColumn"": 0,
""rowSpan"": 2,
""columnSpan"": 5,
""verticalAlignment"": ""Center"",
""enableStyledText"": true,
""text"": ""full name""
""gridRow"": 3,
""gridColumn"": 1,
""columnSpan"": 6,
    DiagramView view = new DiagramView("diagramView1");
    //view.AllowInplaceEdit = true;
    view.SetCustomNodeType(typeof(OrgChartNode));
    view.Diagram.UndoManager.UndoEnabled = true;
    // register current session
    view.RegisterSession(Session);
    // register custom item type
    view.RegisterItemType(typeof(OrgChartNode), "OrgChartNode", "OrgChartNode", 100, template);
    view.LoadFromJson(Request.Form["diagramView1_PostData"]);
    ViewBag.DiagramView = view;
    NodeListView nodeView = new NodeListView("nodeListView1");
    nodeView.NodeSize = new SizeF(96, 40);
    nodeView.DefaultNodeSize = new SizeF(60, 25);
    nodeView.RegisterSession(Session);
    nodeView.LoadFromJson(Request.Form["nodeListView1_PostData"]);
    ViewBag.NodeListView = nodeView;
    if (!IsPost)
        Diagram diagram = view.Diagram;
        var node1 = new OrgChartNode();
        node1.Bounds = new RectangleF(25, 15, 60, 25);
        node1.Title = "Step 1";
        node1.FullName = "<a href='http://www.google.com'>Link</a>";
        node1.Details = "Edit Me.";
        node1.Frame = "Rectangle";
        node1.Brush = new MindFusion.Drawing.SolidBrush(Color.FromArgb(50, Color.ForestGreen));
        node1.HandlesStyle = HandlesStyle.SquareHandles2;
        diagram.Nodes.Add(node1);
        nodeView.AddNode(node1);
@using (Html.BeginForm())
    <div class="controls">
        <input type="submit" name="submitButton" value="submit" />
        <button type="button" onclick="diagram.copyToClipboard()">copy</button>
        <button type="button" onclick="diagram.cutToClipboard()">cut</button>
        <button type="button" onclick="diagram.pasteFromClipboard(5, 5)">paste</button>
        <button type="button" onclick="diagram.undo()">undo</button>
        <button type="button" onclick="diagram.redo()">redo</button>
    </div>
    @Html.NodeListView(((NodeListView)ViewBag.NodeListView), new { style = "width:100px; height:700px;" })
    @Html.DiagramView(((DiagramView)ViewBag.DiagramView).ControlLoadedScript("onLoaded").NodePointedScript("onNodePoint"),
    new { style = "width:800px; height:700px; position:relative;  top:-700px; left:120px;" })
    ItemTypeResolver.Unregister(Session);
<script type="text/javascript">
    var Events = Mindfusion.Diagramming.Events;
    var diagram = null;
        diagram = sender;
        diagram.addEventListener(Events.onHyperlinkClicked, onHyperlinkClicked);
    function onNodePoint(sender, args) {
        alert("Hello! I am an alert box, created by a hover!");
    function onDeleteClick(sender, args) {
        var item = args.getItem();
        item.getParent().deleteItem(item);
    function onHyperlinkClicked(sender, args) {
        window.open(args.getHyperlink());
    function onEditClick(sender, args) {
        sender.beginEdit(args.node, args.mousePosition);
</script>
Reply #9 - Jun 23rd, 2020 at 7:05am
Fix the F case here -
var Events = Mindfusion.Diagramming.Events; ->
The event name is hyperlinkClicked-
diagram.addEventListener(Events.onHyperlinkClicked, onHyperlinkClicked); ->
diagram.addEventListener(Events.hyperlinkClicked, onHyperlinkClicked);
DSI
Reply #10 - Jun 23rd, 2020 at 5:31pm
Thanks a lot!
I am trying to use beginEdit to ONLY allow edit on the "Detail" text component as you mentioned earlier; but as it is now, all text is editable when clicked.  How can I achieve this?
Also, I am using onNodePoint to create a simple js alert.  Is it possible to ONLY activate this alert when the mouse position is over a specific component (say, the "Title" text component)?
Reply #11 - Jun 24th, 2020 at 2:35pm
Try this -
if (args.node.root)
	var component = args.node.root.hitTest(args.getMousePosition());
	if (component == args.node.getComponent("Details"))
