Normal Topic Link Vicinity (Read 4270 times)
bizintel_dan
Link Vicinity
Jun 15th, 2020 at 9:29pm
How can I have link vicinity so links aren't so close together. Is there a way to space out nodes more if I have to grow more room for link boundaries.
Re: Link Vicinity
Reply #1 - Jun 16th, 2020 at 6:32am
Try calling new OrthogonalRouter().Arrange(diagram);
bizintel_dan
Re: Link Vicinity
Reply #2 - Jun 26th, 2020 at 1:12pm
These are layout calls I make
anOrthogonalLayout.Arrange(diagram);
anOrthogonalLayout.Arrange(diagram, diagramitems);
I don't see any link routers that are orthogonal.
I have used with success
MindFusion.Diagramming.Layout.OrthogonalLayout();
MindFusion.Diagramming.Layout.AnnealLayout();
to map out my diagrams
I use a lot of looping to call arrange.
foreach node in diagramnodes
if (gettype() == ContainerNode)
arrange(diagram,getdatagramcollection(node)
These leads to a lot of calling of Arrange.
Should I be using a lot of loop calls to reach nested containers or can I call Arrange(diagram)?
bizintel_dan
Re: Link Vicinity
Reply #3 - Jun 26th, 2020 at 1:18pm
The only problem is the links.
They draw to the middle of tables instead of anchoring on the outside of tables. Unless some links are empty on there column anchor point.
I don't mind them crossing through containers.
Also they get all bunched up in the same lanes.
It looks like all one line in places where there are 10 lines super close together.
How can I get wider lanes?
bizintel_dan
Re: Link Vicinity
Reply #4 - Jun 26th, 2020 at 1:20pm
I use
diagram.RouteAllLinks();
after my looped layout arrange calls to try and get the links where I want them.
Should layout arrange just be used instead?
Re: Link Vicinity
Reply #5 - Jun 26th, 2020 at 2:43pm
OrthogonalRouter is a layout class from the Diagramming.Layout namespace. Try replacing diagram.RouteAllLinks() call with "new MindFusion.Diagramming.Layout.OrthogonalRouter().Arrange(diagram)" one.
bizintel_dan
Re: Link Vicinity
Reply #6 - Jun 26th, 2020 at 6:43pm
The OrthogonalRouter() is a better fit. What properties does it have that I can adjust to get links lanes more spaced out?
Re: Link Vicinity
Reply #7 - Jun 29th, 2020 at 4:58pm
There aren't any properties for distance. The Arrange method should automatically distribute links as much as possible in space between nodes, doesn't it? There's also some weight given to keeping initial distance between links from same node to follow the bundle more easily while they travel in same direction, so space might not be exactly evenly distributed. If it's not working that well with your diagram, please send us the saved file and our developer will investigate.
