Normal Topic Charting for WinForms, V4.1.2 (Read 1591 times)
Jun 17th, 2020 at 9:38am
We have released version 4.1.2 of MindFusion.Charting for WinForms. It contains the following new features and improvements:
Axis origin
The Origin property of Axis class lets you specify the origin of an axis. If set to a non-null value, the component renders an axis line inside the plot. Bars are drawn below that axis line if their values are smaller than the origin. For stacked bar charts, each bar length corresponds to the difference between bar's value and origin.
  • ToolTips property added to SimpleSeries class specifies tooltips for data values.
  • DataLabelsBackground property added to Theme class specifies background of data labels.
  • DataLabelsBorderStroke, DataLabelsBorderDashStyle, DataLabelsBorderThickness properties of Theme class allow displaying and customizing borders around data labels.
https://www.mindfusion.eu/ChartWinForms.zip
Updated assemblies are also available as MindFusion.Charting NuGet package.
« Last Edit: Jan 9th, 2022 at 1:04pm by Forum Admin »
