Normal Topic after adding node in node width changed control points of link disconnect (Read 1401 times)
reshma
Jun 18th, 2020 at 10:33am
I have scope in scope(c2) i have one more node(c1) and i am adding interface between node(c1) and scope(c2) and saving after that i am add two more node(1,2) in node width changed control points showing correct on diagram but when i am saving diagram control points of link disconnected,
Please let me know after adding node within node and changed width i have to save control points .
which method or event here to save control points after adding node?
« Last Edit: Jun 18th, 2020 at 11:55am by reshma »
Re: after adding node in node width changed control points of link disconnect
Reply #1 - Jun 18th, 2020 at 3:56pm
Passing true as second argument of setBounds should realign node's links automatically -
var b2 = node.bounds.clone();
b2.width += 10;
node.setBounds(b2, true);
