Normal Topic Looking for selection change started event (Read 2253 times)
Jan Lyson
Jun 19th, 2020 at 1:46pm
I'm looking for something like 'SelectionStartChanging' event. I have my own undo-redo manager and I need to know what items are affected to collect their state to a single undo-redo unit.
For example, when I have multiple nodes selected, then click on empty space, all nodes are deselected. Every node reacts on 'NodeDeselected' event and reports its change to my undo-redo manager. I need to start collecting before selection change occurs and stop collecting after selection change is completed (there is an event 'SelectedChanged').
I'm able to do this everywhere a call Selection.Clear(), Selection.Change(item) etc on my own, but I'm not able to do this when diagram does it natively - probably somewhere in BehaviorBase class.
Is it possible to achieve this? Can I somehow handle this native behavior on my own?
Jan
Re: Looking for selection change started event
Reply #1 - Jun 22nd, 2020 at 9:03am
Try this -
diagram.NodeSelected += (ss, aa) => ItemSelectionChanged();
diagram.NodeDeselected += (ss, aa) => ItemSelectionChanged();
diagram.LinkSelected += (ss, aa) => ItemSelectionChanged();
diagram.LinkDeselected += (ss, aa) => ItemSelectionChanged();
diagram.SelectionChanged += SelectionChanged;
bool selectionStarted = false;
void ItemSelectionChanged()
	if (!selectionStarted)
		Debug.WriteLine("init selection record");
		selectionStarted = true;
void SelectionChanged(object sender, EventArgs e)
	Debug.WriteLine("done selection record");
Jan Lyson
Reply #2 - Jun 24th, 2020 at 1:58pm
sorry for not responding for a while. It seems your solution works.
Thank you Smiley
Jan
