Very Hot Topic (More than 25 Replies) i want to restrict to move outside node inside scope and can not intersect with scope and vis-versa (Read 15339 times)
reshma
Jul 29th, 2020 at 10:12am
In my diagram i have one scope node and inside that other node and other nodes are in outside scope.
So i want to restrict to move outside node inside scope and outside node can not intersect with scope and vis-versa .
below i have attached one image that contain large one is my scope and some node inside it and outside scope other nodes.
« Last Edit: Jul 29th, 2020 at 11:28am by reshma »
Re: i want to restrict to move outside node inside scope and can not intersect with scope and vis-versa
Reply #1 - Jul 30th, 2020 at 8:00am
Set AllowAddChildren and AllowRemoveChildren properties of ContainerNode to false. You'll be able to add child nodes to the container only from code then.
reshma
Reply #2 - Jul 30th, 2020 at 10:36am
But at the time of creation i have add some node in the scope but once i added after that for modifying i am trying to change width or move outside node to scope should not allow to even intersect
Reply #3 - Jul 30th, 2020 at 1:45pm
You can prevent nodes being dropped at position where they'd intersect with the container from nodeModifying validation event handler. Call node.getBounds().intersect(container.getBounds()) to find if current positions intersect.
reshma
Reply #4 - Jul 31st, 2020 at 7:31am
1) How can i find node is intersect with left side,right ,top and bottom side?
2)How can i find on nodecreated event that added in container child or outside?
3)How to avoid node intersect with other in half and not part of the container child ?
4) how can we find out node is not created exactly in container child it's partially touched?
Finally i do not want overlap any node on other node i want to shift node from current node (for eg if my node is overlap on top side i want shift this node on top of other node so that this can not overlap)
Please let me know .
As i checked your solution with intersect but it is showing intersect even i am adding node in the containerchild so please suggest
« Last Edit: Jul 31st, 2020 at 3:31pm by reshma »
Reply #5 - Aug 3rd, 2020 at 8:15am
let nb = node.getBounds();
let cb = container.getBounds();
if (nb.intersectsWith(cb))
    if (nb.left() <= cb.left() && cb.left() <= nb.right())
        console.log("intersects left");
Reply #6 - Aug 3rd, 2020 at 8:35am
nodeCreated is raised before child node is added to container, and then followed by containerChildAdding / containerChildAdded events. So containerChildAdding is earliest point where you know child node is being added, and you can cancel from it by calling eventArgs.setCancel(true);
Reply #7 - Aug 3rd, 2020 at 8:50am
If you mean allow intersecting a bit but no more than half node's area, try something like
function onNodeModifying(diagram, args)
	var nodes = diagram.getNodes();
	var b1 = args.getNode().getBounds();
	var area1 = b1.width * b1.height;
	for (var i = 0; i < nodes.length; i++)
		if (nodes[i] == args.getNode())
			continue;
		var b2 = nodes[i].getBounds();
		if (b2.intersectsWith(b1))
			var area2 = b2.width * b2.height;
			var bi = b1.intersect(b2);
			var areai = bi.width * bi.height;
			if (areai > area2 / 2 || areai > area1 / 2)
				args.setCancel(true);
or otherwise a direct setCancel(true) to prevent any intersection
Reply #8 - Aug 3rd, 2020 at 8:53am
run same loop as above from nodeCreated / nodeCreating handler to find any intersecting nodes. Add an extra check for nodes[i]' type if you need to avoid intersections only with containers.
Reply #9 - Aug 3rd, 2020 at 8:59am
If you mean allow dropping the node anywhere but then adjusting position, move that loop from nodeModifying / nodeCreating to nodeModified / nodeCreated, and instead setCancel(true), modify the node's bounds as desired. It's not as simple as just aligning the moved node to the intersected one because it might introduce new intersections with nearby nodes. Instead, you might have to loop and shift node by some step until you find unoccupied area. Overall better cancel from validation event and let users find position they like.
reshma
Reply #10 - Aug 3rd, 2020 at 2:07pm
i agree with your solution but i have problem is like i want to find only those intersect that are half part of node is inside and other is outside that means it's not part of container child only those overlap i have to find and for that i will do setcancel true not for all node intersect with(i mean if i am adding in the container child that time also showing intersect this node but that i do not want) .
I want only those overlapped node that are half portion of the node is outside (i mean it is not child of the node) but intersect with some portion of the node.
Reply #11 - Aug 3rd, 2020 at 3:12pm
the cancel condition should be containerRect.intersectsWith(nodeRect) && !containerRect.contains(nodeRect)
reshma
Reply #12 - Aug 13th, 2020 at 9:25am
Thank you,above all answers are useful for me.
i have one more question how to find node is intersect with left side or right side or top side or bottom side.
Reply #13 - Aug 13th, 2020 at 3:13pm
that was shown above, e.g. node intersects left side of container -
Checks for other sides are analogous to left.
reshma
Reply #14 - Aug 17th, 2020 at 12:28pm
how to handle one more scenario for overlapping
suppose i have 3 nodes c1 is parent of c2 and c3 is near to C1 if i try to modify the node c2 then automatically C1 size is increased and C1 and C3 are intersect how to find this?
i have try to find it on containerchildadded event but it's already getting increasing some size so i am not getting exact intersect points .
How to handle both child as well as parent position at original when the parent intersect to other node?
