Normal Topic Custom layout and coordinates calculation (Read 1227 times)
Anna Malashkina
Aug 13th, 2020 at 9:18pm
I implemented custom layout and was able to deploy it via arrange() function. In this way I had got graph in the function instead of diagram.
As far as I can see vertex width and height have come from owner's bounds. But I'm not sure how vertex.x and vertex.y are being transformed back to diagram's coordinates. Could you please explain?
Re: Custom layout and coordinates calculation
Reply #1 - Aug 14th, 2020 at 6:19am
Hi Anna,
Set vertex' X and Y to the center of wanted node position. If inside ContainerNode, positions should be relative to its top/left. Final coordinates are also translated by layout.margins value and other subgraphs' bounds depending on multipleGraphsPlacement. If you don't want your diagram to be split into subgraphs and multipleGraphsPlacement applied, set requiresConnectedGraph field of your layout class to false.
