Normal Topic About the rotating picture of the diagram (Read 1368 times)
JackPan
Aug 21st, 2020 at 11:13am
Hi All, Smiley
Some pictures are slanted like picture one. So I want to automatically correct it to the effect of Figure 2 before displaying it on the digram. How can I achieve it?
Any assistance would be appreciated.
Cheers,
Jack
Re: About the rotating picture of the diagram
Reply #1 - Aug 24th, 2020 at 6:16am
If that's a DiagramNode rotated by user, you can straighten it automatically by setting RotationAngle property to 0.
If the source bitmap contains a rotated image, you will need to use some image recognition algorithm / library to detect and deskew it. E.g. try these:
https://gist.github.com/russss/922be97d2a65eb534744c5a4054ff88d
https://opencv.org/about/
https://stackoverflow.com/questions/43913314/c-sharp-how-to-deskew-an-image
http://www.aforgenet.com/
https://www.codeproject.com/Articles/13615/How-to-deskew-an-image
JackPan
Reply #2 - Aug 24th, 2020 at 7:10am
Hi Slavcho Smiley
Thank you for your valuable answer, I will get the answer I want from it.
Best wishes for you!
