Normal Topic Display X and Y value when hovering on points of line (Read 6073 times)
William
Sep 6th, 2020 at 7:29pm
I am using line chart with Windows form. Do you know how to display X and Y value when hovering on points of line?
William
Re: Display X and Y value when hovering on points of line
Reply #1 - Sep 7th, 2020 at 6:30am
You could set series' tooltips to the X,Y values of each point. If you implement the Series interface yourself, you can generate them automatically from GetLabel(LabelKinds.ToolTip) implementation.
These appear when mouse hovers over a point from the series, and not for segment points in between. If you need the latter, you'll need to show them via custom tooltip.
JackMyers
Reply #2 - Feb 9th, 2023 at 10:31am
I still do not understand how to implement this. I have a line chart with multiple series. What code do I need to use to display Y-axis values when hovering over the individual data points?
Thanks in advance,
Jack
Reply #3 - Feb 9th, 2023 at 12:57pm
E.g. try these two approaches in LineChart example:
var yValues = new List<double> { 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 };
var yTooltips = yValues.Select(y => y.ToString()).ToList();
lineChart.Series.Add(
	new Series2D(
		new List<double> { 0,1,2,3,4,5,6,7,8,9,10,11 },
		yValues, yTooltips
		Title = "Series 2",
		SupportedLabels = LabelKinds.ToolTip /*| LabelKinds.InnerLabel*/
	new YTooltip(
		new Series2D(
			new List<double> { 1,2,3,4,5,6,7,8,9,10,11,12 },
			labels
		{ Title = "Series 1" }));
class YTooltip : Series
	public LabelKinds SupportedLabels =>
		series.SupportedLabels | LabelKinds.ToolTip;
	public string GetLabel(int index, LabelKinds kind)
		if (kind == LabelKinds.ToolTip)
			return series.GetValue(index, 1).ToString();
		return series.GetLabel(index, kind);
	public YTooltip(Series series)
		Debug.Assert(series.Dimensions >= 2);
		this.series = series;
	public int Size => series.Size;
	public int Dimensions => series.Dimensions;
	public string Title => series.Title;
	public double GetValue(int index, int dimension)
		return series.GetValue(index, dimension);
	public bool IsEmphasized(int index) { return series.IsEmphasized(index); }
	public bool IsSorted(int dimension) { return false; }
	public event EventHandler DataChanged;
	Series series;
