Normal Topic Relative movement between diagram and ShapeNode or ShapeNode and ShapeNode (Read 1379 times)
JackPan
Sep 10th, 2020 at 9:23am
Hi, Slavcho Smiley
I want to use the value of the TextBox or the arrow keys to control the movement of the ShapeNode in the diagram, so I need to define an origin coordinate (0,0) position, so that the midpoint of the ShapeNode is relative to the origin (0,0) position movement.
1. I want to set the position of the origin (0, 0) to the upper left corner of the diagram. How do I achieve this?
2. If the origin (0, 0) is set to the center point of another ShapeNode, it means that a ShapeNode moves with the center point of another ShapeNode as the origin. How do I achieve this?
Best regards.
Re: Relative movement between diagram and ShapeNode or ShapeNode and ShapeNode
Reply #1 - Sep 11th, 2020 at 4:46am
You can specify where 0,0 is located in the diagram by setting diagram.Bounds. Move node to coords - size / 2 as in https://mindfusion.eu/Forum/YaBB.pl?num=1598018807/4#4 to get a node centered at specific coordinates.
