Normal Topic How to find on nodecreated event that node parent (container) is available or not? (Read 3118 times)
reshma
Sep 23rd, 2020 at 12:03pm
I want to know parent of node on nodecreated event before Containerchildadded().
Please let me know the property
Re: How to find on nodecreated event that node parent (container) is available or not?
Reply #1 - Sep 24th, 2020 at 6:10am
Before containerChildAdded, earliest you will get the container is as argument of containerChildAdding, as we discussed in https://mindfusion.eu/Forum/YaBB.pl?num=1596017540/6#6
If it's that important to find container from nodeCreated handler, call Diagram.getNodesAt(args.mousePosition) and check if topmost node behind newly created one is container.
reshma
Reply #2 - Sep 24th, 2020 at 8:10am
i added this.diagram.getNodes(args.getMousePosition()) but args.getMousePosition() is undefined on nodecreated event is any other way to find node is having parent on nodecreated event
Reply #3 - Sep 25th, 2020 at 5:50am
Actually mouse position is reported with nodeCreating event but not nodeCreated. You could save last one from creating to check in created, or get it from the Diagram.pointerPosition field.
reshma
Reply #4 - Sep 28th, 2020 at 12:45pm
resolve my problem but i have one more issue which is suppose i have parent and child and i am trying to drag child outside parent it is not allowed (somewhere args.setcancel(True))event is fired can you please let me know which one is the event to find childs are not allowed to move outside parent  and setcancel(true) is applied ( i checked on nodemodifying but it is not there)
Reply #5 - Sep 29th, 2020 at 9:26am
Try the containerChildRemoving event.
