Normal Topic Diagramming for Java Swing, V4.5 (Read 2502 times)
Oct 15th, 2020 at 10:58am
We have released version 4.5 of JDiagram. It contains the following new features and improvements:
SVG nodes
The SvgNode class represents nodes that can display SVG drawings in addition to the rendering provided by its base ShapeNode class. SVG elements are rendered after the associated bitmap Image and just before the drawNode event is raised for Additional custom drawing. SVG elements are parsed and associated with the node through a com.mindfusion.svg.SvgContent object, which should be initialized and then assigned to the Content property. The Factory class contains createSvgNode overloaded methods for creating nodes from SVG files or from already loaded SvgContent instances.
JSON serialization improvements
  • HatchBrush objects are now serialized in JSON files.
  • saveToJsonFile now encodes the JSON content in UTF8 format.
  • Fixed JSON serializaton of pens with null DashStyle.
  • ImagePadding property of ShapeNode, TableNode and Cell lets you set padding space between element's borders and the contained Image.
  • FoldIconSize property added to ContainerNode.
  • Tag property added to the Cell class lets you associate custom data with cells.
  • Fixed drawing glitches when Windows 10 display scaling is enabled.
Installer for the latest version can be downloaded here, or from the clients area on our site.
https://www.mindfusion.eu/JDiagramTrial.zip
« Last Edit: Nov 30th, 2020 at 1:04pm by Forum Admin »
Diagramming for Java Swing, V4.5.1
Reply #1 - Nov 17th, 2020 at 10:10am
v4.5.1 is a maintenance release with following fixes and improvements:
  • The MoveNodes behavior allows grabbing nodes to drag them without using adjustment handles.
  • Fixed tooltips when Windows 10 display scaling is enabled.
  • Fixed inplace-edit when Windows 10 display scaling is enabled.
  • FillMode enum moved from com.mindfusion.diagramming to com.mindfusion.drawing package.
  • Database storage example added.
« Last Edit: Nov 30th, 2020 at 1:05pm by Forum Admin »
