Normal Topic Diagramming for Windows Forms, V6.6.1 (Read 2174 times)
Oct 23rd, 2020 at 10:17am
We have released version 6.6.1 of FlowChart.NET. It contains the following new features and improvements:
CompositeNode Json templates
CompositeNode templates can now be defined in JSON format compatible with MindFusion JavaScript diagramming library:
string template = @"{
 ""component"": ""SimplePanel"",
 ""children"":
   ""component"": ""Shape"",
   ""name"": ""Frame"",
   ""pen"": ""black"",
   ""strokeThickness"": 0.2,
   ""isOutline"": true,
   ""autoProperty"": true
Call the LoadJsonTemplate method to create components from JSON definition. The GenerateJsonTemplate method returns a JSON template generated from current component hierarchy.
  • The MoveNodes behavior allows grabbing nodes to drag them without using adjustment handles.
  • Font fallback is now enabled by default. To disable font fallback, set the NoFontFallback flag in TextFormat property of diagram and items.
  • JSON serialization fixes.
  • SvgContent.LoadImage no longer tries to download SVG dtd schema definitions.
  • Fixed exception in GridRouter.
Updated assemblies are also available as MindFusion.Diagramming NuGet package.
« Last Edit: Nov 30th, 2020 at 1:06pm by Forum Admin »
