Normal Topic Issue with UI DockControl LoadFromXml and SaveToXml calls (Read 1657 times)
MavinTech
Nov 13th, 2020 at 6:35pm
Looking for some direction:
Using the sample code for UI Docking, the functionality of SaveToXml and LoadFromXml works as expected. (XML file is created and read back from).
I added a DockControl and some Items in my code in much the same manner.  I call the SaveToXml and a file is created with the XML code, but the LoadFromXml call returns with 0 Items in it.
I can take the XML file that was created from my code and load it into the sample code correctly, but the Load doesn't work in my code.
Are there any environmental or Xml parser issues that I should concentrate on?  I expected a Save call followed by a Load call would work.
MavinTech
Re: Issue with UI DockControl LoadFromXml and SaveToXml calls
Reply #1 - Nov 13th, 2020 at 7:48pm
Look long enough and it will likely hit you.
Found this in the WinForms section.  Works for me!
https://mindfusion.eu/Forum/YaBB.pl?num=1534894405
