Hot Topic (More than 10 Replies) Use the example:DirTree.CS to customize the control (Read 6879 times)
JackPan
Re: Use the example:DirTree.CS to customize the control
Reply #15 - Nov 19th, 2020 at 12:57pm
    I got it, thank you Smiley
JackPan
Reply #16 - Nov 19th, 2020 at 1:48pm
I will solve this problem myself, please forgive my ignorance. If there is any business logic related to MindFusion WPF in the future, I will ask you as before, thank you for your answers!  Wink
    Best regards.
Reply #17 - Nov 19th, 2020 at 6:04pm
You've pretty much written several pages of specification above. If you are new to WPF, you might hire some developer experienced in WPF UIs to code that for you - they should be able to do it in a few days of work.
Best regards,
JackPan
Reply #18 - Nov 20th, 2020 at 12:39am
    Thank you for your suggestion, I will consider it, but I still want to write it myself. After all, I also want to master WPF. Wink
    Best wishes for you.
    Jack.
