Normal Topic Ellipse over Dataserie vb.net (Read 2817 times)
Aapo
Nov 22nd, 2020 at 12:13pm
hello,
I have Dataserie and I need Ellipse over that data. I have calculated Eigenvalues, Covarience/inv(cov), means etc.
But I need a sample code for help to do that with mindfusion.
I use vs2015 with Extreme mathematics+MF and vb.net
br aapo
Re: Ellipse over Dataserie vb.net
Reply #1 - Nov 23rd, 2020 at 7:55am
If you mean drawing ellipses at data point locations, you might try adding a BubbleRenderer to chart's Plot, however BubbleRenderer draws circles with same X/Y radius. If you need different X/Y radii, you might have to create a custom series renderer, e.g. here's BubbleRenderer drawing code you could adapt for your scenario:
protected internal override void Draw(RenderContext context)
    EnumVisiblePoints(context, (s, i, point) =>
        var d = (float)Series[s].GetValue(i, 2) * 2;
        using (var brush = EffectiveFill(s, i, context).CreateGdiBrush(new RectangleF(point.X - d / 2, point.Y - d / 2, d, d)))
            context.Graphics.FillEllipse(brush, point.X - d / 2, point.Y - d / 2, d, d);
        using (var pen = EffectiveStrokePen(s, i, context).CreateGdiPen())
            context.Graphics.DrawEllipse(pen, point.X - d / 2, point.Y - d / 2, d, d);
If that ellipse of yours shows some cumulative / mean value derived from main series data, you could represent it as a separate series containing a single data point.
Aapo
Reply #2 - Nov 25th, 2020 at 1:43pm
Thank's for these advices.  I try continue with that
br Aapo
