Normal Topic Issue trying to copy a link line to the clipboard (Read 2961 times)
MavinTech
Dec 8th, 2020 at 3:21pm
I am using the diagram control similar to a canvas control with items on it.  To draw a line segment, I add a Link Line to the diagram where I have "AllowUnconnedtedLinks="true".
When I try to copy the link to clipboard (Ctrl-C), I get an error.  It works with the ShapeNodes I use, but if there is a LinkLine in the selection to copy, it gives me the exception.
LinkLine_copy_error.txt (Attachment deleted)
Re: Issue trying to copy a link line to the clipboard
Reply #1 - Dec 8th, 2020 at 4:24pm
This build should fix that -
https://mindfusion.eu/_temp/wpfdiag_copy_link.zip
MavinTech
Reply #2 - Dec 10th, 2020 at 9:06pm
That worked for when I use Ctrl-C and Ctrl-V.  Multiple nodes and multiple links are copied and then pasted.
Shouldn't that also work for the CopyToClipboard and PasteFromClipboard?  What I'm getting there is the nodes will copy and paste, but the links will not.
Reply #3 - Dec 11th, 2020 at 8:11am
Have you tried the PasteFromClipboard(...unconnectedLinks) overload?
