Normal Topic Need to know the current DockItem at all times. (Read 4140 times)
MavinTech
Dec 23rd, 2020 at 4:18pm
Looking for an event that can fire when a DockControl's DockItem is selected.  I tried GotFocus, but it didn't happen when I clicked on a tab of a tabbed Item.  Was hoping for a DockControl_OnSelectionChanged type of event.
I basically need to know what the "current" DockItem is within the DockControl as the user selects various items.
Also, is there a way to prevent a user from closing/hiding an item.
Re: Need to know the current DockItem at all times.
Reply #1 - Dec 28th, 2020 at 2:43pm
There's the SelectedItem property in DockWindowBase (from which e.g. TabbedDocument and DockWindow derive). I can't see any event raised when it changes, maybe try binding your own property to it to get notified when it gets set, or see second answer here -
https://stackoverflow.com/questions/4764916/listen-to-changes-of-dependency-prop...
We'll have in mind adding some global event in DockControl for next release.
MavinTech
Reply #2 - Dec 28th, 2020 at 4:20pm
Tried to set this up with the UI.DockControl sample code supplied with the WPFPack and I'm getting lost.  Would you be able to throw together some sample code based on that sample code?
My current need is a two sided document (front and back) where each side is a diagram control inside a DockItem.
Reply #3 - Dec 29th, 2020 at 2:25pm
E.g. this will detect active tab changes in the TabbedDocument:
var tabDoc = dockControl.Items.OfType<TabbedDocument>().FirstOrDefault();
if (tabDoc != null)
    SetBinding(
            SelectedItemProperty,
            new Binding
                Source = tabDoc,
                Path = new PropertyPath(DockWindowBase.SelectedItemProperty),
                Mode = BindingMode.OneWay
DependencyProperty SelectedItemProperty = DependencyProperty.Register(
    "SelectedItem", typeof(DockItem), typeof(Window1),
    new PropertyMetadata(OnSelectedItemChanged));
static void OnSelectedItemChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
    var dockItem = (DockItem)e.NewValue;
    Debug.WriteLine("OnSelectedItemChanged: " + dockItem.Content);
Anyway we should have an event for this early next year Wink
MavinTech
Reply #4 - Dec 29th, 2020 at 3:28pm
I will incorporate this into my code.  Thanks for the help.
For the added feature coming, it would be very useful to include selection of any DockItem within the DockControl? (DockWindow item, floating, autohidden, etc...).
Thanks again.
Reply #5 - Dec 30th, 2020 at 3:50pm
This build adds ItemClosing validation event -
https://mindfusion.eu/_temp/dock_closing.zip
void dockControl_ItemClosing(object sender, ItemValidationEventArgs e)
    if (MessageBox.Show(
        "Are you sure you want to close unsaved document?",
        "Document changed", MessageBoxButton.YesNo) != MessageBoxResult.Yes)
        e.Cancel = true;
Reply #6 - Jan 8th, 2021 at 7:49am
New build adds ItemSelected event -
