Normal Topic TreeLayout Mindfusion (Read 5882 times)
Zain Ahmed
Jan 12th, 2021 at 6:18pm
Hi everone!.
I am using Mindfusion diagramming. I want to make an Organogram in react. for that I installed npm mindfusion-common
and npm-diagram-library-react. but when i execute the code, it returns this error:
"TypeError: Cannot read property 'TreeLayout' of undefined"
Can anyone help me with this?
Thanks, Zain
Online
Re: TreeLayout Mindfusion
Reply #1 - Jan 12th, 2021 at 6:35pm
Hi!
You can find TreeLayout used in the Samples\React\src\Inheritance.js example. Doesn't it work for you when you do npm install & npm start (in parent folder)?
Zain Ahmed
Reply #2 - Jan 13th, 2021 at 7:40am
Hi Thanks for the time!
Actually I copied to code of Organogram from Mindfusion website. It worked fine in the simple HTML file. But when I moved to React it gave errors, then I install mindfusion library and imported
'mindfusion-common' which solved many errors. Now it's giving an error on the line :
"var TreeLayout = MindFusion.Graphs.TreeLayout;"
I don't know what to do now. I installed react-library too but in vain. Kindly help me
Zain Ahmed
Reply #3 - Jan 13th, 2021 at 8:19am
Update:
So I added two more imports which nearly solved the error :
Now it is saying "Can not read property 'id' of null" in the file
"MindFusion.Common" and in the following lines:
var cg = new cb(cf, cc);
[b('0x4a')] = cf;
this[b('0x9')](cg);
this[b('0x4b')][b('0x4c')](cf['id'], cg);
cg[b('0x31')]();
return cg;
It shows the organogram for a second and disappears afterwards.
Online
Reply #4 - Jan 13th, 2021 at 9:19am
Have you placed the diagram canvas inside a div? The control expects a parent div serving as scroll-view, tooltip container and other DOM access operations. Otherwise please attach your test html and js code and our developer will investigate.
Online
Reply #5 - Jan 13th, 2021 at 9:37am
By Organigram do you mean this example of ours? We'll try to adapt it to React later today...
https://mindfusion.eu/blog/organization-services-chart-with-the-javascript-diagr...
Online
Reply #6 - Jan 13th, 2021 at 11:08am
We've added that code as a new tab in the React example -
https://mindfusion.eu/_samples/React.OrgChart.zip
Zain Ahmed
Reply #7 - Jan 13th, 2021 at 1:21pm
Hi thanks for the help. I solved it somehow, but my request would be to upload as much videos as possible on your YouTube channel showing how to use MindFusion products Smiley
Online
Reply #8 - Jan 13th, 2021 at 3:44pm
Okay, we'll multiply them Wink
