Normal Topic Exception calling Diagram.LoadFromStream(stream) (Read 2221 times)
David Long
Jan 13th, 2021 at 10:18am
I am getting an "Unable to read beyond the end of a stream" exception when calling Diagram.LoadFromStream().  I'm guessing that maybe there was something wrong with the Diagram when it was saved, although no exception was reported.  Is there anyway I can find out what that problem with the Diagram is?
This is a customer's file and although the problem is rare I am sure we have had this problem before, so we are very keen to get it fixed.
Regards
DavidL
Re: Exception calling Diagram.LoadFromStream(stream)
Reply #1 - Jan 13th, 2021 at 10:36am
There isn't unless you trace the code using a debug build. Please attach the file and we'll inspect.
If you save any custom Tag objects along with the diagram items by implementing ISerializable, make sure they read as may bytes as were written in any possible execution path.
The file could also get corrupted due to incomplete network transfer, file system errors and such.
David Long
Reply #2 - Jan 13th, 2021 at 2:26pm
File is too large to attach to this post. Do you have an email I can send it to?
DavidL
Reply #3 - Jan 13th, 2021 at 2:41pm
support at this website's domain.
