Normal Topic UndoRedo grouping for multiple nodes being moved (Read 2015 times)
MavinTech
Feb 16th, 2021 at 3:01pm
I am performing some custom actions in the OnNodeModified handler.  When multiple nodes are selected and moved, this handler is fired once for each node for movement.  That's fine until I need to perform an undo.  How do I know within the handler that it will be firing multiple times so that I can group my actions into a single command?
Re: UndoRedo grouping for multiple nodes being moved
Reply #1 - Feb 17th, 2021 at 9:08am
You could defer your custom actions to SelectionModified handler when you detect Selection.Items.Count > 1.
