Normal Topic PasteFromClipboard pasting in wring order (Read 2365 times)
David Long
Feb 18th, 2021 at 2:23pm
With our DiagramView and Diagram setup we have discovered that you can select multiple boxes by drawing a rectangle over multiple boxes with the left mouse button. But when we use CopyToClipboard() followed by PasteFromClipboard() the boxes are pasted in the order they were created rather than their order on screen (also the order in which they were "dragged over").
How can we overcome this behaviour?
DavidL
Re: PasteFromClipboard pasting in wring order
Reply #1 - Feb 18th, 2021 at 4:35pm
Creation order is also used as default Z order, so we like copy/paste better this way Smiley You could sort diagram.Selection.Items before calling CopyToClipboard if you need them copied in left-to-right or top-to-bottom order. E.g. the Sort comparer could just return item1.Bounds.X.CompareTo(item2.Bounds.X);
David Long
Re: PasteFromClipboard pasting in wrong order
Reply #2 - Feb 18th, 2021 at 5:41pm
Ok, I'll have a look at this, but the clients can Ctrl+Click on boxes in any order, copy them to the clipboard and then paste them elsewhere in the order clicked on. I would like to let them continue doing this. I'll see if the events I get indicate a dragged rectangle type of selection. In which case I can do what you suggest.
DavidL
David Long
Reply #3 - Feb 19th, 2021 at 12:58pm
Problem solved. Although I did have to re-sort the boxes after I had pasted them from the clipboard, but before I re-connected them to the target box. I can share some code if anyone is interested.
Thanks for your help.
DavidL
