Normal Topic Diagramming for JavaScript, V3.5.4 (Read 1920 times)
May 3rd, 2021 at 8:07am
We have released version 3.5.4 of MindFusion JavaScript Diagram library. It contains the following new features and improvements:
Stock themes
The library now includes nine stock themes, accessible via respective static methods of the Theme class. Call the setTheme method of Diagram to apply a theme.
Blue Business Earth
Gray Green Light
Pastel Peach Standard
  • The MoveNodes behavior allows grabbing nodes to drag them without using adjustment handles.
  • New SelectedBrush and SelectedStroke properties of Style used to draw selected items.
  • CaptionBackBrush of ContainerNode and TableNode objects can now be set via Style instead of nodes' own properties.
  • Fix for resizeToFitText not calculating correct size when cells have text padding applied.
  • BackColor and TextColor properties added to NodeListView.
  • ToolTip property of AnchorPoint shows tooltip text when mouse hovers over the point.
  • Various fixes for React, Vue and Angular bindings.
  • New Scripting.js sample project demonstrates ControlNode objects and graph traversal.
Updated scripts are also available as diagram-library NPM package.
