Normal Topic Data Binding on the AllowDrop property in DiagramNode (Read 1969 times)
Jan Lyson
Jun 4th, 2021 at 7:35am
I was tasked at work to implement a drag&drop operation from one place in our application into one of the DiagamNodes. What I have noticed is that every node has the AllowDrop property data binding set without ever specifying the binding myself.
Is this something that is set and used internally in the Diagram component and if so, is there a way I can work around it and implement the d&d operation?
Thanks for your help,
JL
Re: Data Binding on the AllowDrop property in DiagramNode
Reply #1 - Jun 4th, 2021 at 7:56am
It is indeed bound to diagram's AllowDrop. You could remove the binding by calling System.Windows.Data.BindingOperations.ClearBinding, or just process the node from diagram's own events:
void OnDiagramDragOver(object sender, DragEventArgs e)
    var position = e.GetPosition(diagram.DocumentPlane);
    var node = diagram.GetNodeAt(position);
    if (node == thatSpecificNode)
        e.Effects = DragDropEffects.Copy;
    else
        e.Effects = DragDropEffects.None;
    e.Handled = true;
void OnDiagramDrop(object sender, DragEventArgs e)
        node.Text = (string)e.Data.GetData(typeof(string));
    e.Handled = true;
Jan Lyson
Reply #2 - Jun 4th, 2021 at 8:15am
Let's say I go with clearing the binding manually. Would this potentially break any functionality of the Diagram itself?
Another question, when is the binding being set? I noticed that during the initialization of the DiagramNode the binding is still not set (and not clearable), not even during the OnRender call.
Is there an extensibility point that I can use to access the property after it's been initialized?
Thanks for the fast answer!
Reply #3 - Jun 4th, 2021 at 8:24am
It's bound mostly to let the diagram receive these drag and drop events at any position once you enable its own property, otherwise nodes with disabled AllowDrop prevent it. We can't think of adverse effects from unbinding the node if you don't care about handling drag and drop for the whole diagram. The binding is created when node is added as diagram's child element, e.g. try clearing from ItemAdded or NodeCreated event handler.
Jan Lyson
Reply #4 - Jun 4th, 2021 at 10:00am
Ok, thank you very much for your helpful answers.
