Normal Topic How to avoid "stop" mouse pointer during linking? (Read 2874 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Jul 15th, 2021 at 6:27pm
When I try to create link between two nodes by drag, the arrow head is shown as in the screen shot. But along with that the mouse pointer is "stop" icon? May I know how to avoid the stop icon?
Kannan
Re: How to avoid "stop" mouse pointer during linking?
Reply #1 - Jul 19th, 2021 at 6:04am
You could enable AllowUnconnectedLinks property of diagram to allow creating the link even if not connecting to a node. If you still want to prevent unconnected links but just disable mouse pointer indication, set the MindFusion.Controls.MouseCursors.NotAllowed value to CSS cursor name that you prefer. Defaults are shown below.
MindFusion.Controls.MouseCursors = {
	Auto: "auto", // The UA determines the cursor to display based on the current context.
	Crosshair: "crosshair", // A simple crosshair (e.g., short line segments resembling a "+" sign).
	Default: "default", // The platform-dependent default cursor. Often rendered as an arrow.
	Pointer: "pointer",
	Move: "move",
	HorizontalResize: "ew-resize",
	CounterDiagonalResize: "nesw-resize",
	DiagonalResize: "nwse-resize",
	VerticalResize: "ns-resize",
	Text: "text", // Indicates text that may be selected. Often rendered as an I-beam.
	Wait: "wait",
	Help: "help",
	Progress: "progress",
	Inherit: "inherit",
	Rotate: "all-scroll",
	Nothing: "null",
	NotAllowed: "not-allowed",
	Pan: "all-scroll"
Kannan Thirumal
Senior Member
Reply #2 - Jul 19th, 2021 at 9:37am
I need to set AllowUnconnectedLinks false because we don't need unconnected links. But want the mouse pointer to default mouse arrow cursor. May I know how to do with MindFusion.Controls.MouseCursors.NotAllowed?
Kannan
Reply #3 - Jul 19th, 2021 at 9:41am
Try setting MindFusion.Controls.MouseCursors.NotAllowed = "default"; // or "pointer"
Kannan Thirumal
Senior Member
Reply #4 - Jul 19th, 2021 at 9:53am
I tried this earlier but giving this compile error. Am I missing anything?
ERROR in app/diagram/diagram.component.ts:174:25 - error TS2339: Property 'MouseCursors' does not exist on type 'typeof Controls'.
174     MindFusion.Controls.MouseCursors.NotAllowed = "default";
Do I want to try like this?
(MindFusion.Controls as any).MouseCursors.NotAllowed = "default";
Is this fine or any other approach?
Kannan
Reply #5 - Jul 19th, 2021 at 10:01am
Apparently we don't have MouseCursors defined in d.ts file if you are trying to set it from TypeScript. Try this instead:
MindFusion.Controls["MouseCursors"].NotAllowed = "default";
Kannan Thirumal
Senior Member
Reply #6 - Jul 19th, 2021 at 6:28pm
This seems working. Thank you!
